[postgis-users] new user = new problems
Shoaib Burq
hydromap at gmail.com
Thu May 25 09:53:53 PDT 2006
Alternativly you can create a new postgis specific template see link
below for instructions:
http://wiki.nomad-labs.dyndns.org/nomadlabs/published/Creating+a+postgis+template+database
shoaib
On 5/25/06, Mark Cave-Ayland <m.cave-ayland at webbased.co.uk> wrote:
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> > bounces at postgis.refractions.net] On Behalf Of Bruce Rindahl
> > Sent: 24 May 2006 18:15
> > To: 'PostGIS Users Discussion'
> > Subject: RE: [postgis-users] new user = new problems
> > I used the windows installer and that's what mine is. I don't think I
> > changed any of the defaults.
> > Bruce
> Hi Bruce/Mike,
> Just for reference, this is a PostgreSQL change, mainly to prevent naïve
> clients connecting to template1 by default which was causing some database
> commands to block. See below for more information.
> http://archives.postgresql.org/pgsql-committers/2005-06/msg00302.php.
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended recipient
> and may also be privileged. If you are not the intended recipient please
> delete it from your system and notify the sender. You should not copy it or
> use it for any purpose nor disclose or distribute its contents to any other
> person.
> postgis-users mailing list
