[postgis-users] Do I always have to use AddGeometryColumn?
Galen Ward galen at shackprices.com
Wed May 24 10:17:22 PDT 2006
Sort of a newbie question here: The PostGis manual
(http://www.postgis.org/docs/ch03.html#id2917099) seems to indicate that I
always have to use the AddGeometryColumn function to properly create
metadata and spatial fields, but that makes it difficult to backup and move
databases.  Will the same tables be created from a dump?  I.E. can I use
this to create a table:
	  the_geom geometry,
	  CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
	  CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom)
= 	'POINT'::text OR the_geom IS NULL),
	  CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4269
Instead of this:
	AddGeometryColumn(...)?
Thanks for your help!
-Galen
