[postgis-users] Do I always have to use AddGeometryColumn?
Frank Koormann
frank.koormann at intevation.de
Wed May 24 11:19:15 PDT 2006
* Galen Ward <galen at shackprices.com> [060524 19:17]:
> Sort of a newbie question here: The PostGis manual
> (http://www.postgis.org/docs/ch03.html#id2917099) seems to indicate that I
> always have to use the AddGeometryColumn function to properly create
> metadata and spatial fields, but that makes it difficult to backup and move
> databases. Will the same tables be created from a dump?
If you are dumping / restoring full databases - yes. If you are only
dumping / restoring the single table containing the geometries you have
to consider the geometry_columns table explicitely.
> I.E. can I use
> this to create a table:
> the_geom geometry,
> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom)
> = 'POINT'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4269
> Instead of this:
> AddGeometryColumn(...)?
Yes, you can use the above. However in that case no record inthe
geometry_columns table is created with the metadata. That is no problem
for PostGIS, but some client applications may rely on this OGC SF
structures.
HTH,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
