[postgis-users] displaying a specific extent of the map
David William Bitner
bitner at gyttja.org
Fri May 26 06:23:31 PDT 2006
I think that Mark was trying to point out that this is _not_ a javascript
list, but rather a list dedicated to the PostGIS extension to the PostgreSQL
database. The two code snips that you show have nothing at all to do with
PostGIS.
On 5/26/06, simflex <simflex at millenniumhealthproducts.com> wrote:
> hi Mark,
> I don't believe that sql server is the problem.
> Rather these 2 code snips:
> <script>
> function zoomToExt ent(box) {
> box_array = box.split(" ");
> minx = box_array[0]*1;
> miny = box_array[1]*1;
> maxx = box_array[2]*1;
> maxy = box_array[3]*1;
> width = (maxx - minx) + 200;
> height = maxy - miny;
> centerx = minx + (width / 2.0);
> centery = miny + (height / 2.0);
> lonlatPt = map.mcsToLonLat(centerx, centery);
> lon = lonlatPt.getX();
> lat = lonlatPt.getY();
> map.zoomWidth(lat, lon, width, 'FT');
> </script>
> <td>
> <a href="#" onClick="zoomToExtent('<%=tan%>');return
> false;">
> <font size="-1"><%=incidentlocation%></font>
> </a>
> </td>
> First of all, I am getting an error on the following lines:
> If I remove them, then the following don't do anything at all:
> <td>
> false;">
> </a>
> </td>
> Not sure what I am doing wrong here.
> -----Original message-----
> From: "Mark Cave-Ayland" m.cave-ayland at webbased.co.uk
> Date: Thu, 25 May 2006 10:49:21 -0400
> To: "'PostGIS Users Discussion'" postgis-users at postgis.refractions.net
> Subject: RE: [postgis -users] displaying a specific extent of the map
> > PostGIS is a spatial extension for PostgreSQL (http://www.postgresql.org
> > ) rather than MS-SQL Server. I'd suggest you
> > need to ask on either an MS-SQL or an ASP/Javascript coding site for
> help,
> > but without more information it's impossible to determine exactly what
> the
> > problem you're experiencing is.
> > Kind regards,
> > Mark.
> > WebBased Ltd
> > 17 Research Way
> > Plymouth
> > PL6 8BT
> > T: +44 (0)1752 797131
> > F: +44 (0)1752 791023
> > http://www.webbased.co.uk
> > http://www.infomapper.com
> > http://www.swtc.co.uk
> > This email and any attachments are confidential to the intended
> recipient
> > and may also be privileged. If you are not the intended recipient
> please< BR>> delete it from your system and notify the sender. You should
> not copy it or
> > use it for any purpose nor disclose or distribute its contents to any
> other
> > person.
> > _____
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> simflex
> > Sent: 25 May 2006 14:16
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] displaying a specific extent of the map
> > Greetings all,
> > First time user of this forum.
> > We use a sql server db to store data including x, y values. and using
> ASP on
> > the front end to retrieve data
> > Currently, we are do have a summary report laid out thus:
> > incident id first name last name incident type, incident location
> > 1 John Doe vehicular amber
> > street
> *> Our issue arises because we want to be able to click on incident id to
> zoom*
> > directly to the extent of the map where the incident occurred.
> > so far, we are struggling with this. any ideas would greatly
> appreciated.
> > Here is what we have got so far:
> > Set cn=Server.CreateObject("ADODB.Connection")
> > nID = Request("RecordID")
> > 'response.write nID
> > 'response. end
> > cn.Open "Driver={SQL Server};" & _
> > "Server=haoi;" & _
> > "Address=haoi,1433;" & _
> > "Network=DBMSSOCN;" & _
> > "Database=incidentsDB;" & _
> > "Uid=sa;" & _
> > "Pwd="
> > SQL = "select incident_LOC, id,minlat,minlon,maxlat,maxlon from
> Incidents
> > where id =" & nID
> > Set rs = cn.Execute( SQL )
> > 'response.write SQL
> > 'response.end
> > cnt = 0
> > Do Until cur.EOF
> > cnt = cnt + 1
> > incidentlocation = cur(0).Value
> > recnum = CLng(cur(1).Value)
> > ileft = CLng(cur(2).value) - 250
> > ibottom = CLng(cur(3).Value) - 250
> > iright = CLng(cur(4).Value) + 250
> > itop = CLng(cur(5).Value) + 250
> > ; tan = ileft & " " & ibottom & " " & iright & " " & itop
> > <#10b70bee894b4b1b_>
> > cur.MoveNext
> > Loop
> > if cnt = 0 Then
> > *No results*
> > End If
> > rs.Close()
> > cn.Close()
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060526/5bff3b7f/attachment.html>
