[postgis-users] Correct dump and restore
Stefan Schwarzer
stefan.schwarzer at grid.unep.ch
Mon Nov 13 01:51:30 PST 2006
> You have both:
> /usr/local/bin/psql
> and
> /usr/local/pgsql/bin/psql
> The former doesn't work, the latter does.
> When exporting your PATH you *append* /usr/local/pgsql/bin to
> the existing $PATH, which likely includes /usr/local/bin.
> Try *prepending* it instead:
> export PATH="/usr/local/pgsql/bin:$PATH"
> Also, check with 'which psql' to make sure the correct one is being
> foundn (bash keeps known binaries in an hash, you can clean it up
> using
> 'hash -r')
> --strk;
Great, that seemed to be it! Thanks a lot!
I now have this command (with an encoding param):
schwarzer$ sh temp/downloads/postgis-1.1.6/utils/postgis_restore.pl /
usr/local/pgsql/share/contrib/lwpostgis.sql geodataportal_utf8 temp/
dump_geodataportal_utf8_2006-11-13.sql --encoding=UTF_8 > restore.log
It gives me the following notice & erros. Anything serious
(especially with the errors at the bottom)?
NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
NOTICE: argument type histogram2d is only a shell
NOTICE: type "spheroid" is not yet defined
NOTICE: argument type spheroid is only a shell
NOTICE: type "geometry" is not yet defined
NOTICE: argument type geometry is only a shell
NOTICE: return type geometry is only a shell
NOTICE: type "box3d" is not yet defined
NOTICE: argument type box3d is only a shell
NOTICE: type "chip" is not yet defined
NOTICE: argument type chip is only a shell
NOTICE: type "box2d" is not yet defined
NOTICE: argument type box2d is only a shell
NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index
"spatial_ref_sys_pkey" for table "spatial_ref_sys"
"geometry_columns_pk" for table "geometry_columns"
ERROR: language "plpgsql" already exists
ERROR: could not access file "$libdir/liblwgeom.so.1.1": No such
file or directory
ERROR: function public.affine(geometry, double precision, double
precision, double precision, double precision, double precision,
double precision, double precision, double precision, double
precision, double precision, double precision, double precision) does
not exist
