[postgis-users] extending a database with another table
Kirk R. Wythers
kwythers at umn.edu
Thu Nov 16 05:47:11 PST 2006
Thanks for your patience Jan.
krw
On Nov 15, 2006, at 8:01 AM, Jan Syryn wrote:
> Your question has nothing to do with PostGis problems, but is merely a
> general DB design problem.
> But because we are all nice guysz all together:
> Don't add a table 'airports'.
> Just extend station with a column stationtype_id(char 1) that
> points (fk) to
> another table
> 'stationtype'.
> Stationtype with id(char1) and stationtype_name(varchar(20))
> Fill it with ('S' ; 'Station') and ('A', 'Airport')
> Problem solved.
> You want solar and climate for airports:
> SELECT climate.*, solar.*
> FROM climate,solar,station
> WHERE climate.station_id = station.station_id
> AND solar.station_id = station.station_id
> AND station.stationtype_id='A'
> Replace 'A' by 'S' for stations.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Kirk R.
> Wythers
> Sent: mardi 14 novembre 2006 21:49
> To: PostGIS Discussion Users
> Subject: [postgis-users] extending a database with another table
> I am looking for suggestions on database design.
> I have a simple three table database that holds climate data. The
> first
> table (stations) holds station id, and geoposition information.
> The second table (climate) holds temp and precip information, and
> the third
> table (solar) holds solar radiation data. The column station_id
> acts as a
> foreign key to link the tables.
> My trouble is that I need to add a forth table (airports) that in
> the same
> manner as "stations" in that it contains a station_id number, on
> which data
> lines from "solar" and "climate" key off of. The goal here is to be
> able to
> differentiate solar data from airports and solar data from the
> stations.
> Below are the three current tables (stations, climate, and solar).
> Any ideas would be most appreciated.
> met_data=# \d stations
> Table "public.stations"
> Column | Type | Modifiers
> station_id | integer | not null
> station_name | character varying |
> state | character varying |
> lat | double precision |
> lon | double precision |
> the_geom_lonlat | geometry |
> the_geom_meters | geometry |
> Indexes:
> "stations_pkey" PRIMARY KEY, btree (station_id)
> "stations_station_id_key" UNIQUE, btree (station_id) Check
> constraints:
> "enforce_dims_the_geom_lonlat" CHECK (ndims(the_geom_lonlat) = 2)
> "enforce_dims_the_geom_meters" CHECK (ndims(the_geom_meters) = 2)
> "enforce_geotype_the_geom_lonlat" CHECK (geometrytype
> (the_geom_lonlat) = 'POINT'::text OR the_geom_lonlat IS NULL)
> "enforce_geotype_the_geom_meters" CHECK (geometrytype
> (the_geom_meters) = 'POINT'::text OR the_geom_meters IS NULL)
> "enforce_srid_the_geom_lonlat" CHECK (srid(the_geom_lonlat) =
> 4269)
> "enforce_srid_the_geom_meters" CHECK (srid(the_geom_meters) =
> 32661)
> met_data=# \d climate
> Table "public.climate"
> year | smallint |
> month | smallint |
> day | smallint |
> doy | smallint |
> date | date |
> precip | real |
> tmin | real |
> tmax | real |
> Foreign-key constraints:
> "climatefk" FOREIGN KEY (station_id) REFERENCES stations
> (station_id)
> met_data=# \d solar
> Table "public.solar"
> year | smallint |
> month | smallint |
> day | smallint |
> doy | smallint |
> date | date |
> solar | real |
> "solarfk" FOREIGN KEY (station_id) REFERENCES stations
> (station_id)
> postgis-users mailing list
