[postgis-users] Hibernate with PostGIS
Norman Barker nbarker at ittvis.com
Thu Nov 16 07:38:51 PST 2006
Sandeep,
To use JBoss EJB3 with PostGIS I had to write a Hibernate Geometry
Driver, the source code is in PostGIS SVN (LGPL) and there is a tutorial
available here
http://postgis.refractions.net/support/wiki/index.php?SpatialEJB3
It allows creation and updates through Java, the tutorial walks you
through a simple SOAP example.
I am very interested in using the hibernate lucene annotations
(http://www.hibernate.org/hib_docs/annotations/reference/en/html/lucene.
html) in conjunction with the Geometry driver to create some sort of
catalog; so that we can do a proper geometry search on PostGIS through
the business layer (not just boxes!) and then seach on metadata with
Lucene.
A couple of people have expressed interest in this hibernate geometry
driver for Java, please give me some feedback on the future direction
you want this to go.
Thanks,
Norman
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Sandeep Kumar Jakkaraju
Sent: 16 November 2006 15:30
To: PostGIS Users Discussion
Subject: [postgis-users] Hibernate with PostGIS
Hi All
I want to know if i can use Hibernate with PostGIS ??
if yes ..then can some one point me to some doc which tells abt this !!
I am just skeptical about the geometry column !!
Thanks
Sandeep
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061116/706fc523/attachment.html>
