[postgis-users] Hibernate with PostGIS
Sandeep Kumar Jakkaraju
sandeepkumar.jakkaraju at gmail.com
Thu Nov 16 09:58:10 PST 2006
Hi Norman
For using Hibernate with postgis ..i can directly use ur postgis.jar !!
right ...??
Your Tutorial mainly aimed at using EJB3 with postgis ...
did u think of using Spring instead of EJB3 !! ??
Thanks
Sandeep
On 11/16/06, Norman Barker <nbarker at ittvis.com> wrote:
> Sandeep,
> To use JBoss EJB3 with PostGIS I had to write a Hibernate Geometry Driver,
> the source code is in PostGIS SVN (LGPL) and there is a tutorial available
> here
> http://postgis.refractions.net/support/wiki/index.php?SpatialEJB3
> It allows creation and updates through Java, the tutorial walks you
> through a simple SOAP example.
> I am very interested in using the hibernate lucene annotations (
> http://www.hibernate.org/hib_docs/annotations/reference/en/html/lucene.html)
> in conjunction with the Geometry driver to create some sort of catalog; so
> that we can do a proper geometry search on PostGIS through the business
> layer (not just boxes!) and then seach on metadata with Lucene.
> A couple of people have expressed interest in this hibernate geometry
> driver for Java, please give me some feedback on the future direction you
> want this to go.
> Thanks,
> Norman
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Sandeep
> Kumar Jakkaraju
> *Sent:* 16 November 2006 15:30
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] Hibernate with PostGIS
> Hi All
> I want to know if i can use Hibernate with PostGIS ??
> if yes ..then can some one point me to some doc which tells abt this !!
> I am just skeptical about the geometry column !!
> Thanks
> Sandeep
> postgis-users mailing list
WeBlog:
http://jakkarajus.blogspot.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061116/162357e3/attachment.html>
