[postgis-users] PosGis shutdown with request using within
Markus Schaber schabi at logix-tt.com
Mon Oct 2 07:35:10 PDT 2006
Hi, Xavier,
Xavier Mauclaire wrote:
> All thegemetries hhave been tested with the isvalid() function.
> I don't understand why the within operator fails even though geometris are
> valids
> Beside this, the only logs i get is that the postmaster process aws
> terminated by signal 11
OK. So it seems that there's a bug in either PostGIS or GEOS.
Do you have the possibility to update to the newest versions (PostGIS
just released 1.1.3)?
Can you create a self-contained test-case (dump those two geometries)
for within causing the postmaster process to terminate, and for causing
the postmaster process to use 100% CPU?
Thanks,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf.     | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
