[postgis-users] PosGis shutdown with request using within
Xavier Mauclaire
xavier.mauclaire at geoter.fr
Mon Oct 2 07:25:05 PDT 2006
Hi
All thegemetries hhave been tested with the isvalid() function.
I don't understand why the within operator fails even though geometris are
valids
Beside this, the only logs i get is that the postmaster process aws
terminated by signal 11
regards
Xavier Mauclaire
Service informatique
GEOTER SAS
3, rue Jean Monnet
34830 Clapiers France
Tél.: +33 (0)4.67.59.18.11
Fax: +33 (0)4.67.59.18.24
Email: xavier.mauclaire at geoter.fr
Web site: http://www.geoter.fr
-----Message d'origine-----
De : postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] De la part de Markus
Schaber
Envoyé : lundi 2 octobre 2006 16:08
À : PostGIS Users Discussion
Objet : Re: [postgis-users] PosGis shutdown with request using within
Hi, Xavier,
Xavier Mauclaire wrote:
> The system becomes instable and i've to to do a hard reset of the
> machine I can't stop the process neither with postgresql restart not pgctl
-m ...
> Under window a can restart the service BUT i've got to do that to kill
> the postmaster process linked to th request This request uses 99
> pourcent of the CPU and the connection is usually broken after
> sometimes
You should be able to kill the backend process via the task manager.
Some "within" queries may need lots of CPU time for complex polygons.
That the query shutdowns the Postmaster process seems to be a bug.
Can you try to identify some pairs of geometries that forthe the Postmaster
to shutdown?
And can you run isvalid() against all geometries involved, to make shure
they're all valid?
Thanks,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf. | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org _______________________________________________
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
__________ Information NOD32 1.1786 (20061002) __________
Ce message a ete verifie par NOD32 Antivirus System.
http://www.nod32.com
