--- Just van den Broecke <just at justobjects.nl> wrote: > Hi, > > I have a problem using INSERT of POINTs in a geometry column defined by > AddGeometryColumn() with dimension 0. Try setting your dimension value for your points column to 2. (I have no idea why, but it works for me...) Brent Wood
