[postgis-users] enforce_dims_geom error (JDBC)
Barend K=?ISO-8859-1?B?9g==?=bben
kobben at itc.nl
Wed Oct 4 23:40:18 PDT 2006
That is I think because the Dimension in this case is not the "mathematical
dimension" where point = 0, line = 1, area =2, but it rather is the
dimension of the cooridnates use, ie, 2= x&y, 3 = X&y&z, 4=X&y&z&T(ime)
Bye,
__
Barend Köbben
International Institute for Geo-information
Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
On 05-10-2006 07:43, "Brent Wood" <pcreso at pcreso.com> wrote:
> --- Just van den Broecke <just at justobjects.nl> wrote:
>> Hi,
>> I have a problem using INSERT of POINTs in a geometry column defined by
>> AddGeometryColumn() with dimension 0.
> Try setting your dimension value for your points column to 2. (I have no idea
> why, but it works for me...)
> Brent Wood
> postgis-users mailing list
