[postgis-users] Newbie question #2 -- visualizing large datasets?
Dylan Beaudette dylan.beaudette at gmail.com
Tue Oct 10 13:17:07 PDT 2006
Hi Jonathan, others:
I normally use QGIS to visualize a subset of the massive geometries that i
maintain in postgis. I would recommend a couple ways of working with a
subset:
using limit: SELECT ... FROM ... LIMIT 1000;
creating a view based on the intersection of your geometries, and some
bounding box:
a rather complex example of this can be found here:
http://casoilresource.lawr.ucdavis.edu/drupal/node/265
Cheers,
Dylan
On Tuesday 10 October 2006 11:25, Craig Miller wrote:
> Try using "generalize" in your PostGIS query to limit the number of
> vertices that are returned when zoomed way out.
> --Craig
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Jonathan Greenberg
> Sent: Tuesday, October 10, 2006 11:17 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Newbie question #2 -- visualizing large datasets?
> Is there a way to visualize massive databases of points or polygons?  I'm
> talking data much larger than I've been able to display in arc or grass
> environments using their basic vector coverage formats.  Thanks!
> --j
> Jonathan A. Greenberg, PhD
> NRC Research Associate
> NASA Ames Research Center
> MS 242-4
> Moffett Field, CA 94035-1000
> Office: 650-604-5896
> Cell: 415-794-5043
> AIM: jgrn307
> MSN: jgrn307 at hotmail.com
> postgis-users mailing list
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
