[postgis-users] Restore data from Mac to Windows fails
TECHER David
davidtecher at yahoo.fr
Wed Oct 11 06:00:20 PDT 2006
Hi Barrend
When I do a backup from Windows to my laptop on Linux, I'm used to do on
my laptop before "backuping"
cp /usr/local/pgsql/lib/liblwgeom.1.1.so /usr/local/pgsql/lib/liblwgeom.dll
and it works :-)
So from Mac to Windows
on windows, i think you need to copy liblwgeom.dll to liblwgeom.1.1.so
copy c:\PostgreSQL\...\liblwgeom.dll C:\liblwgeom.1.1.so
But I don't know if it works!
--david;
http://www.davidgis.fr
Barend Köbben a écrit :
>Hi,
>I am trying to restore a database backup up from the Mac-version of PostgreSQL8.1.4+PostGIS1.1.1 to a Windows server installation (same versions), first by using PGadminII, then by following the pg_dump-pg_restore story in the Postgres manual. I have try many (combinations of) settings, compress, tar, plain, with and without blobs, etc...
>It fails. I first thought it was a general Postgres thing, but it seems the culprit is a PostGIS function, looking at the error message that always comes up :
>pg_restore: creating FUNCTION box2d_in(cstring)
>pg_restore: [archiver (db)] Error while PROCESSING TOC:
>pg_restore: [archiver (db)] Error from TOC entry 19; 1255 52517 FUNCTION box2d_in(cstring) root
>pg_restore: [archiver (db)] could not execute query: ERROR: could not access file "$libdir/liblwgeom.1.1.so": No such file or directory
> Command was: CREATE FUNCTION box2d_in(cstring) RETURNS box2d
> AS '$libdir/liblwgeom.1.1.so', 'BOX2DFLOAT4_in'
> LANGUAGE c IMMUTABLE...
>The only workaround I could find was backuing up the schema and data seperately as SQL inserts, then deleting the PostGIS function part from the schema SQL , and running bot in psql... Not very nice.
>Has anybody an idea how to solve it?
>PS: I noticed that what the Mac version of PGadminIII calls ENCODING=UNICODE, the Win version calls ENCODING=UTF8. Surely this is just a naming problem, not the cause...?
>Barend Köbben
>International Institute for Geo-information
>Sciences and Earth Observation (ITC)
>PO Box 6, 7500AA Enschede (The Netherlands)
>ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
