[postgis-users] [jdbc][datasource] use postgis through JDBC in Spring
Nicolas Delsaux nicolas.delsaux at gmail.com
Wed Oct 18 06:54:10 PDT 2006
Hi, is there anywhere a tutorial on PostGIS integration in JEE
environments using containers like Spring or, even simpler,
datasources instead of connections ?
I suspect geotools provides a layer for connection, but will it remove
the need for me to addDataTypes manually ?
Nicolas Delsaux
N'imprimez ce mail que si vous ne savez pas le lire sur l'écran : les
électrons se recyclent bien, le papier, beaucoup moins bien.
