[postgis-users] Appending geometry data from another table
Bruce Rindahl rindahl at lrcwe.com
Fri Oct 20 10:33:57 PDT 2006
I have an existing table that I want to append new data from another table.
I can't figure out how to append the geometry.  My query looks something
like this:
INSERT into county_parcels SELECT
'Archuleta' as county,
the_geom as the_geom
 FROM county_temp;
The error is:
ERROR:  column "the_geom" is of type geometry but expression is of type
character varying
HINT:  You will need to rewrite or cast the expression.
How do I cast the geometry from the first table to insert into the second
one?
Thanks
Bruce Rindahl
