[postgis-users] [More Asks]: GeoTiff into PostGIS
Paul Ramsey
pramsey at refractions.net
Mon Oct 23 12:23:05 PDT 2006
Why not leave your GeoTIFF outside the database and skip the middleman. What is
the database providing you that you don't get just leaving it where it is?
Quoting Ricardo <ricardoluis at ufs.br>:
> > Date: Fri, 20 Oct 2006 13:35:31 -0700
> > From: Paul Ramsey <pramsey at refractions.net>
> > Subject: Re: [postgis-users] GeoTiff into PostGIS
> > To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> > Message-ID: <91709AF9-A842-47E6-8DD1-AE4F9485C5F3 at refractions.net>
> > Content-Type: text/plain; charset=ISO-8859-1; delsp=yes; format=flowed
> > All kinds of ways. What are you planning on doing with it once you
> > get it there?
> > Paul
> > On 20-Oct-06, at 1:29 PM, Ricardo wrote:
> > > Hi all,
> > > How can I load a GeoTiff file into my PostGIS data base?
> > > thanks you all.
> > > Ricardo Luís
> > > _______________________________________________
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Hi Paul,
> I want to use the GDAL library to read a GeoTiff from my PostGIS data base,
> what is the best or easy way to load this file, exist some utility to do
> this for me? I must to use sql commands? What are my options, where can I
> found samples?
> :D
> Thank you for your reply,
> Ricardo Luís
