[postgis-users] Coordinate transformation problem
strk at refractions.net strk at refractions.net
Tue Oct 24 05:06:05 PDT 2006
Just a note, in current SVN the spatial_ref_sys table
have been updated to EPSG 6.11.1
--strk;
On Tue, Oct 24, 2006 at 01:52:34PM +0200, Arnaud Lesauvage wrote:
> Guido Lemoine a écrit :
> >Are you sure your Belgian Lambert 1972 has SRID 31370, and not 31300??
> I tried both projections actually ("Belge 1972" and "Belgian
> 1972").
> The content of my .prj file is :
> PROJCS["Belge_Lambert_1972",
> GEOGCS["GCS_Belge_1972",
> DATUM["D_Belge_1972",SPHEROID["International_1924",6378388,297]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.0174532925199432955]],
> PROJECTION["Lambert_Conformal_Conic"],
> PARAMETER["False_Easting",150000.01256],
> PARAMETER["False_Northing",5400088.4378],
> PARAMETER["Central_Meridian",4.367486666666666],
> PARAMETER["Standard_Parallel_1",49.8333339],
> PARAMETER["Standard_Parallel_2",51.16666733333333],
> PARAMETER["Latitude_Of_Origin",90],UNIT["Meter",1]]
> If you check in your spatial_ref_sys table, this is 31370.
> I have even added a new line in spatial_ref_sys with this
> projection's exact parameters, but the difference with the
> "real" 31370 projection is only ~2 or 3 millimeters.
> Arnaud
> postgis-users mailing list
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
