[postgis-users] Coordinate transformation problem
Guido Lemoine
guido.lemoine at jrc.it
Tue Oct 24 05:15:48 PDT 2006
I have been working on geocoding of SAR imagery over Belgium areas.
I found back a remark in an E-mail to my collegue who used the data for
agricultural area assessment. It says:
"I have used the correct datum shifts between the WGS84 and LCC2.
I found them on a web site and they are in the order of 80 m and 120 m
in X and Y"
But I can't remember which web site, and in what direction I applied the
shift.
This seems to be in the order of your shift.
Guido
Arnaud Lesauvage wrote:
> Guido Lemoine a écrit :
>> Are you sure your Belgian Lambert 1972 has SRID 31370, and not 31300??
> I tried both projections actually ("Belge 1972" and "Belgian 1972").
> The content of my .prj file is :
> PROJCS["Belge_Lambert_1972",
> GEOGCS["GCS_Belge_1972",
> DATUM["D_Belge_1972",SPHEROID["International_1924",6378388,297]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.0174532925199432955]],
> PROJECTION["Lambert_Conformal_Conic"],
> PARAMETER["False_Easting",150000.01256],
> PARAMETER["False_Northing",5400088.4378],
> PARAMETER["Central_Meridian",4.367486666666666],
> PARAMETER["Standard_Parallel_1",49.8333339],
> PARAMETER["Standard_Parallel_2",51.16666733333333],
> PARAMETER["Latitude_Of_Origin",90],UNIT["Meter",1]]
> If you check in your spatial_ref_sys table, this is 31370.
> I have even added a new line in spatial_ref_sys with this projection's
> exact parameters, but the difference with the "real" 31370 projection
> is only ~2 or 3 millimeters.
> Arnaud
> postgis-users mailing list
Joint Research Centre, European Commission
Institute for the Protection and Security of the Citizen (IPSC)
Unit: Support to External Security
Via E. Fermi, 1 TP 267 Ispra 21020 (VA), Italy
Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
WWW: http://ses.jrc.it
Disclaimer:
Views expressed are those of the individual and do not represent the
views of the European Commission
