[postgis-users] GIST index create failure
Dave Stone D.Stone at ed.ac.uk
Wed Oct 25 09:03:09 PDT 2006
I'm trying to create a spatial index on a simple table with a geometry
column. I've tried doing this via the PostgreSQL command line and using
phppgAdmin. So for table 'loccoords' with column 'geom' of type
'geometry', the SQL is:
create index loccoords_gistix on loccoords using gist(geom
gist_geometry_ops);
and the result is:
server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
Has anyone met this before? I have successfully created a GIST index
before (on an earlier version of the same table, with fewer than the
present 357 rows).
I'm running PostgreSQL 8.0.8 and PostGIS 1.0.6.
Any suggestions gratefully received!
Dave
