[postgis-users] What SRID is the USGS 24k Quad Grid?
Paragon Corporation
lr at paragoncorporation.com
Tue Oct 31 03:48:00 PST 2006
Thanks Paul and Mike,
The closest match to this in the table appears to be 2163. I think Mike Fuhr was right about the 4167, and then I
projected that to 32661, but depending on which software I used to display 32661 it either looked straight-up or
was rotated 90 degrees. Projecting to 2163 gave more appealing results. I guess 32661 is missing a parameter that
different software are guessing at.
Anyrate - I have another problem. The quad24 is nice but a little too granular and the quad100 is not granular
enough. I'm guessing I need to simplify the geometry. Would I use the simplify function for that? I recall when
I did that, I got some bizarre holes, but that could be because I wasn't sure what to put in for tolerance.
Thanks,
Regina
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Monday, October 30, 2006 11:14 AM
To: lr at paragoncorporation.com; PostGIS Users Discussion
Subject: Re: [postgis-users] What SRID is the USGS 24k Quad Grid?
I've seen that grid once apon a time... is it this?
PROJCS["USA Lambert",GEOGCS["GCS_USA_Sphere",DATUM
["USA_Sphere",SPHEROID["SPHERE",6370977.0,0]],PRIMEM["Greenwich",
0],UNIT["Degree",0.017453292519943295]],PROJECTION
["Lambert_Azimuthal_Equal_Area"],PARAMETER["False_Easting",
0],PARAMETER["False_Northing",0],PARAMETER
["Central_Meridian",-100],PARAMETER["Latitude_Of_Origin",45],UNIT
["Meter",1]]
On 30-Oct-06, at 12:34 AM, Paragon Corporation wrote:
> No that didn't work. The actual data is not in degrees. I think its
> in meters of some sort, but not sure which one. My fear is that its
> more than one SRID like it's a set of UTM ones and so I would have to
> change my SRID for each slice as the UTM zone changes.
> Thanks,
> Regina
> From: Michael Fuhr [mailto:mike at fuhr.org]
> Sent: Sunday, October 29, 2006 10:14 PM
> On Sun, Oct 29, 2006 at 09:34:58PM -0500, Paragon Corporation wrote:
>> I wanted to use the USGS 24K Quad Grid for some statistical analysis.
>> Unfortunately I don't know what the spatial reference system is that
>> is used.
>> The file is located here
>> http://data.geocomm.com/catalog
>> and is the USGS 24Quad Grid file.
> I didn't see any metadata so I'd guess 4267 (longlat NAD27) or maybe
> 4269 (longlat NAD83).
> Michael Fuhr
> postgis-users mailing list
