[postgis-users] What SRID is the USGS 24k Quad Grid?
Obe, Regina robe.dnd at cityofboston.gov
Mon Oct 30 06:32:53 PST 2006
 Mike,
Thanks.  I wasn't quite sure why it didn't look like degree data.  I
must have been looking in a really small text window.  I'll try both
then.
Thanks again,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Michael Fuhr
Sent: Monday, October 30, 2006 9:27 AM
To: lr at paragoncorporation.com; PostGIS Users Discussion
Subject: Re: [postgis-users] What SRID is the USGS 24k Quad Grid?
On Mon, Oct 30, 2006 at 03:34:40AM -0500, Paragon Corporation wrote:
> No that didn't work. The actual data is not in degrees.  I think its
> in meters of some sort, but not sure which one.  My fear is that its
> more than one SRID like it's a set of UTM ones and so I would have to
> change my SRID for each slice as the UTM zone changes.
Which data are you downloading?  I looked at "USGS 24K Quad Grid
(2 MB, SHP format)":
ftp://download1.geocomm.com/sd2/usgs_24kgrid.zip
That data is indeed in degrees:
% shp2pgsql -w 24kgrid.shp test
INSERT INTO "test" ("name","state","lat","long","mrc",the_geom) VALUES
('(ALL WATER)','WA','47.750','-124.625','47124-G6',
GeometryFromText('MULTIPOLYGON(((-124.75 47.75,-124.75 47.875,-124.625
47.875,-124.625 47.75,-124.75 47.75)))',-1) );
Michael Fuhr
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
