[postgis-users] Problems testing the installation of postGIS
strk at refractions.net strk at refractions.net
Sat Sep 2 04:24:55 PDT 2006
On Tue, Aug 22, 2006 at 09:42:29AM -0600, Vincent J. Troisi wrote:
> I'm having a bit of a problem testing the installation of PostGIS.
> I followed the procedure published on the web site for building and
> installing the PostGIS interfaces to postgreSQL. However, I am receiving
> the following messages when I try to test access to the database. Has
> anyone seen this problem
> before? Any ideas on how to correct the problem to enable me to successfully
> test the utilities?
The best way to test is running 'make check' from top-level dir.
This would test the *uninstalled* version.
--strk;
