[postgis-users] What's the Purpose of the Geometry_Columns Table?
TECHER David
davidtecher at yahoo.fr
Tue Sep 5 06:46:49 PDT 2006
U're right! ;-)
Emilia Venturato a écrit :
>Alle 15:14, martedì 5 settembre 2006, Bill Thoen ha probabilmente scritto:
>>I created a table using a 'SELECT * INTO ...' statement which contained a
>>geometry column, and then I performed a few more spatial selections on it
>>without problems. Later I realized that the geometry column in my new table
>>wasn't referenced in the Geometry_Columns, but it didn't seem to matter. So
>>what is the purpose of the Geometry_Columns table?
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>Geometry_columns is a table (OGC standard) that allows other apps (Mapserver,
>QuantumGIS, ecc.) to use postgis data. All standard OGC applications looks at
>geometry_columns to have a complete overview of geographic data in your
>database.
>If you work only in postgis, you can forget about geometry_columns but you'll
>find problems when you will use your data from other applications (mapserver
>for example doesn't show geographical data if geometry_columns is not
>correct).
>At least, that's how I understand it.
>bye
>Lia
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060905/caeeab9c/attachment.html>
