[postgis-users] Problem compiling postgis 1.1.3
Carles Rubio carlos at consulting-it.com
Thu Sep 7 09:34:44 PDT 2006
I try to compile postgis using the follows commands:
1) ./configure --with-proj=/usr/local/proj --with-geos=/usr/local/geos/bin/geos-config
2) LDFLAGS=-lstdc++ ./configure --with-proj=/usr/local/proj --with-geos=/usr/local/geos/bin/geos-config
Then in both cases appears the follow error:
/lwgeom_chip.c: In function `chip_draw_pixel':
lwgeom_chip.c:714: parse error before `p'
lwgeom_chip.c:723: `p' undeclared (first use in this function)
lwgeom_chip.c:723: (Each undeclared identifier is reported only once
lwgeom_chip.c:723: for each function it appears in.)
lwgeom_chip.c: In function `CHIP_dump':
lwgeom_chip.c:1100: parse error before `p'
lwgeom_chip.c:1101: `p' undeclared (first use in this function)
make[1]: *** [lwgeom_chip.o] Error 1
make[1]: Saliendo directorio `/home/soft/postgis-1.1.3/lwgeom'
make: *** [liblwgeom] Error 2
/Please, someone can help me with this problem.
Thanks in advance
Carles
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060907/cb7ff7a3/attachment.html>
