[postgis-users] Problem compiling postgis 1.1.3
TECHER David
davidtecher at yahoo.fr
Thu Sep 7 09:50:45 PDT 2006
Hi Carles
Can U please answer to the following questions in order to us helping U:
then perhaps someone will be able to help U ;-)
1) What distrib do U use? (debian, ubuntu ....)
2) Did U install Geos, Proj and PostgreSQL manually?
Geos ->
Proj ->
PostgreSQL ->
3) What did U get from the following commands U used with 'configure'
for PostGIS?
I mean
SUMMARY
HOST_OS: l???
PGSQL: ???
GEOS: ???
(ldflags: ???)
PROJ: ???
ICONV: ?
PORTNAME: ???
PREFIX: ???
EPREFIX: ${prefix}
DOC: ???
DATA: ???
MAN: ???
BIN: ???
EXT: ??? (\$$libdir)
4) Did U do 'make clean'
thanks
Carles Rubio a écrit :
>I try to compile postgis using the follows commands:
>1) ./configure --with-proj=/usr/local/proj --with-geos=/usr/local/geos/bin/geos-config
>2) LDFLAGS=-lstdc++ ./configure --with-proj=/usr/local/proj --with-geos=/usr/local/geos/bin/geos-config
>Then in both cases appears the follow error:
>/lwgeom_chip.c: In function `chip_draw_pixel':
>lwgeom_chip.c:714: parse error before `p'
>lwgeom_chip.c:723: `p' undeclared (first use in this function)
>lwgeom_chip.c:723: (Each undeclared identifier is reported only once
>lwgeom_chip.c:723: for each function it appears in.)
>lwgeom_chip.c: In function `CHIP_dump':
>lwgeom_chip.c:1100: parse error before `p'
>lwgeom_chip.c:1101: `p' undeclared (first use in this function)
>make[1]: *** [lwgeom_chip.o] Error 1
>make[1]: Saliendo directorio `/home/soft/postgis-1.1.3/lwgeom'
>make: *** [liblwgeom] Error 2
>/Please, someone can help me with this problem.
>Thanks in advance
>Carles
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
___________________________________________________________________________
Découvrez un nouveau moyen de poser toutes vos questions quelque soit le sujet !
Yahoo! Questions/Réponses pour partager vos connaissances, vos opinions et vos expériences.
http://fr.answers.yahoo.com
