[postgis-users] compute "difference" between two roads
c. m.
cesare__m at hotmail.com
Fri Sep 8 06:38:09 PDT 2006
hi all,
thanks a lot again. i'have attached the two source table's and the result
table (diff). i have restricted the test data set to a street I know that
leads partially into a forest.
here the query again:
select s.*, difference(s.wkb_geometry, f.intersection_geom) as diff_geom
into test_diff
from test_sidestreets as s, test_foreststreets as f
where s.feature_id = f.feature_id
>From: Stephen Woodbridge <woodbri at swoodbridge.com>
>Reply-To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>Subject: Re: [postgis-users] compute "difference" between two roads
>Date: Fri, 08 Sep 2006 08:48:12 -0400
>cesare,
>I think it would be helpful if you could post the geomerty for a reference
>line, a line you would expect in the difference set and a line that you
>would expect to get filtered out (likely the same as the reference line).
>Then it will be easier to see what data you are dealing with and how to
>construct an appropriate query. So a dump of a table(s) with with a few
>lines that meet these requirements would be helpful.
>-Steve
>c. m. wrote:
>>hi michael,
>>thanks a lot that you're trying to help me. i'm quite new to the whole
>>thing. do you mean small db table's e.g. concerning one street?
>>cesare
>>>From: Michael Fuhr <mike at fuhr.org>
>>>Date: Fri, 8 Sep 2006 05:30:49 -0600
>>>On Fri, Sep 08, 2006 at 09:38:23AM +0200, c. m. wrote:
>>> > i'm using the navteq data set, postgis/postgres and the uml
>>> > mapserver. Actually I have created a table with forest streets and
>>> > one with side streets. forest streets are a subset of side streets,
>>> > i.e. a forest street is also a side street. now I want to
>>> > geometrically compute the difference of the two (side - forest
>>> > streets) to get an adjacent side streets table (layer) to be able
>>> > to display them properly and independently on the mapserver. as a
>>> > result I always get the entire side street and not the difference
>>> > between the two areas/lines...unfortunately it doesn't work and I
>>> > can't understand why.
>>>Could you post a couple of geometries along with the difference
>>>you get?
>>>Michael Fuhr
>>>_______________________________________________
>>>postgis-users mailing list
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060908/e6309e26/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060908/e6309e26/attachment-0001.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060908/e6309e26/attachment-0002.obj>
