[postgis-users] Problem compiling postgis 1.1.3 #2
TECHER David davidtecher at yahoo.fr
Fri Sep 8 18:01:27 PDT 2006
Hi Carles
I'm not sure this is the solution
but did U run
ldconfig -v | grep libgeos
did U get something like
  libgeos???? -> libgeos???
Let me know ;-)
if not
ldconfig
make && make install
Carles Rubio a écrit :
> Thanks to all by your help,
> The previous problem is solved in the follow sources:
> lwgeom/lwgeom_chip.c
> lwgeom/lwgeom_dump.c
> Just as it commented Michael and --strk .. etc. if we declare the
> variable at first of the function the script compiles perfectly.
> But now I have a new problem. Is the following one:
> //usr/bin/ld: cannot find -lgeos
> collect2: ld returned 1 exit status
> make[1]: *** [liblwgeom.so.1.1] Error 1
> /I look the file /etc/ld.so.conf and exist a line with
> '/usr/local/geos/lib' also in the .configure exist the command
> '--with-geos=/usr/local/geos/bin/geos-config' then I have looked this
> file and there is this portion of code:
> /case $1 in
>     --prefix)
>     echo /usr/local/geos
>     --version)
>     echo 2.1.4
>     --cflags)
>     echo -I/usr/local/geos/include
>     --libs)
>       echo -L/usr/local/geos/lib -lgeos
>     --includes)
>       echo /usr/local/geos/include
>     --jtsport)
>     echo 1.4.1
>       usage 1 1>&2
>   esac
> Apparently this code refers to that link but then the error mentioned
> leaves.
> In the following lines I show you the summary of the .configure:
> /SUMMARY
>  HOST_OS: linux-gnu
>    PGSQL: /usr/local/pgsql/bin/pg_config
>     GEOS: /usr/local/geos/bin/geos-config
>           (ldflags: )
>     PROJ: prefix=/usr/local/proj libdir=/usr/local/proj/lib
>    ICONV: 1
>  PORTNAME: linux
>    PREFIX: /usr/local/pgsql
>   EPREFIX: ${prefix}
>       DOC: /usr/local/pgsql/doc/contrib
>      DATA: /usr/local/pgsql/share/contrib
>       MAN: /usr/local/pgsql/man
>       BIN: /usr/local/pgsql/bin
>       EXT: /usr/local/pgsql/lib (\$$libdir)
> Thanks in advance
> Carles
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
--david;
http://www.postgis.fr
http://www.davidgis.fr
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060909/9c308780/attachment.html>
