[postgis-users] RE: RE: PostGIS - hibernate - EJB3
Daniel Martinez dmtz98 at yahoo.com
Fri Sep 8 09:07:50 PDT 2006
Hello,
I implemented Norman's solution and got the same problem, with the column getting defined as 'oid' instead of 'geometry'.
I finally found a fix that worked for me. It's actually very simple. All I do is set a 'columnDefinition' for the field in the EJB entity bean. Like this.
    @Type(type="mycode.ejb.par.GeometryType")
    @Column(name="LOCATION",columnDefinition="geometry")
    public org.postgis.Geometry getPoint() {
        return _point;
I set the 'columnDefinition' to 'geometry', and it seems to work. The column gets created as type 'geometry'.
Hope this helps.
Norman, thanks for your solution!
Daniel
Do you Yahoo!?
 Get on board. You're invited to try the new Yahoo! Mail.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060908/392c6fb8/attachment.html>
