[postgis-users] ogr2ogr creating shapefile
Frances Collier
fcollier at preparedresponse.com
Tue Sep 12 12:32:46 PDT 2006
Thank you for your reply, David. I did copy and post the question to the
gdal-dev mailing list. In the meantime, though, I tried using pgsql2shp. My
exact syntax:
Pgsql2shp -f D:\myshapefile.shp -u postgres -P postgres mydb 'Select * from
getPop()'
The print out is: Initializing... Querying for attributes: ERROR: syntax
error at or near "Select" at character 152 Now, I've tried putting both
single and double quotes around mydb and around the select statement. If I
don't have the single quotes around the select statement it returns back an
error stating that the table Select does not exist.
And getPop() is a function that I wrote. If you'd like that code, let me
know.
Thank you,
Frances Collier
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of TECHER
David
Sent: Monday, September 11, 2006 4:56 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ogr2ogr creating shapefile
Hi Frances,
I'm used to using ogr2ogr but I've never had problems.
Never see this error before! For me to understanding what is getPop() in
your query???
What about using pgsql2shp instead of ogr2ogr ??? (see
http://postgis.refractions.net/docs/ch04.html#id2524054)
example: pgsql2shp -f your_shapefile.shp your_database your_query
for us to see if U have error too with this tool
For the error U give, it seems better to ask on gdal mailing list!
Frances Collier a écrit :
>Hello all,
>I have been trying to figure out how to create a shapefile using ogr2ogr. I
>haven't been able to find much on it through google and the user pages so I
>thought one of you might be able to help.
>Here's my statement:
>ogr2ogr -f "ESRI Shapefile" test "PG:dbname=mydb host=localhost
>user=postgres password=postgres" -sql "Select pop from getPop()"
>When I click enter I get an Application Error that states the memory could
>not be "read". I'm sure it's in my syntax, but I can't figure it out. I
>would like to know if there are other ways to accomplish this as well.
>Thank you,
>Frances Collier
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
--david;
http://www.postgis.fr
http://www.davidgis.fr
___________________________________________________________________________
Dcouvrez un nouveau moyen de poser toutes vos questions quelque soit le
sujet !
Yahoo! Questions/Rponses pour partager vos connaissances, vos opinions et
vos expriences.
http://fr.answers.yahoo.com
