[postgis-users] ogr2ogr creating shapefile
Bill Thoen bthoen at gisnet.com
Tue Sep 12 12:50:11 PDT 2006
Oddly enough, 'Select' must be lower case for this to work.
On Tue, Sep 12, 2006 at 12:32:46PM -0700, Frances Collier wrote:
> Thank you for your reply, David. I did copy and post the question to the
> gdal-dev mailing list. In the meantime, though, I tried using pgsql2shp. My
> exact syntax:
> Pgsql2shp -f D:\myshapefile.shp -u postgres -P postgres mydb 'Select * from
> getPop()'
> The print out is: Initializing... Querying for attributes: ERROR: syntax
> error at or near "Select" at character 152  Now, I've tried putting both
> single and double quotes around mydb and around the select statement. If I
> don't have the single quotes around the select statement it returns back an
> error stating that the table Select does not exist.
> And getPop() is a function that I wrote. If you'd like that code, let me
> know.
> Thank you,
> Frances Collier
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of TECHER
> David
> Sent: Monday, September 11, 2006 4:56 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] ogr2ogr creating shapefile
> Hi Frances,
> I'm used to using ogr2ogr but I've never had problems.
> Never see this error before! For me to understanding what is getPop() in
> your query???
> What about using pgsql2shp instead of ogr2ogr ??? (see
> http://postgis.refractions.net/docs/ch04.html#id2524054)
> example: pgsql2shp -f your_shapefile.shp your_database your_query
> for us to see if U have error too with this tool
> For the error U give, it seems better to ask on gdal mailing list!
> Frances Collier a écrit :
> >Hello all,
> >I have been trying to figure out how to create a shapefile using ogr2ogr. I
> >haven't been able to find much on it through google and the user pages so I
> >thought one of you might be able to help.
> >Here's my statement:
> >ogr2ogr -f "ESRI Shapefile" test "PG:dbname=mydb host=localhost
> >user=postgres password=postgres" -sql "Select pop from getPop()"
> >When I click enter I get an Application Error that states the memory could
> >not be "read". I'm sure it's in my syntax, but I can't figure it out. I
> >would like to know if there are other ways to accomplish this as well.
> >Thank you,
> >Frances Collier
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
> --david;
> http://www.postgis.fr
> http://www.davidgis.fr
> ___________________________________________________________________________
> Dcouvrez un nouveau moyen de poser toutes vos questions quelque soit le
> sujet !
> Yahoo! Questions/Rponses pour partager vos connaissances, vos opinions et
> vos expriences.
> http://fr.answers.yahoo.com
