[postgis-users] Shp2pgsql - ability to generate a linestring table
Paul Ramsey pramsey at refractions.net
Sat Sep 16 02:44:57 PDT 2006
The shape file format does not distinguish between LINESTRING and
MULTILINESTRING.   Non-aggregate linestrings are simply encoded as 1-
element multilinestrings.  In order for shp2pgsql to correctly figure
out the right type, it would have to scan the whole shape file
initially and check the number of elements in each feature to ensure
none have > 1.
You can turn your shapes into ordinary linestrings post-process
inside PostGIS if you like, by using the GeometryN() function.  Make
sure you also test beforehand that none of your shapes is an
aggregate by using "select count(*) from mytable where numgeometries
(the_geom) > 1"
Paul
On 15-Sep-06, at 12:15 PM, Stewart Nimmo wrote:
> When running "shp2pgsql" on a polyline shape file,  the resulting
> table is
> always a geometry type "multilinestring".  I am expecting and
> require a
> geometry type of  "linestring" .
> Is "multilinestring" the default geometry type for polyline shape
> files
> being converted with shp2pgsql.
> Regards
> Stewart
> <winmail.dat>
> postgis-users mailing list
