[postgis-users] O.T. Problem exporting to MapInfo TAB with ogr2ogr from postgreSQL
Bill Thoen bthoen at gisnet.com
Sat Sep 16 08:18:40 PDT 2006
I asked this question twice on the GDAL list and got no response, so I
thought I'd try a related, but more active, list. Does anyone have any
insight into this?
I just installed gdal 1.3.2 (compiled from source using the default
settings) so I could use ogr2ogr to convert data in PostgreSQL to
MapInfo, but I'm getting some weird results. First, I tried:
ogr2ogr -f "MapInfo File" test.tab "PG:dbname=spatial1" -sql "select *
from napp2"
I expected trouble with this because there are two geometries for each
record; a point and a polygon. But I got a file where  all records
mapped to the same point location and all fields were rendered as
char(254). So if you have multiple geometries, how do you specify the
one you want?
Next I tried a table with only one geometry. I typed:
ogr2ogr -f "MapInfo File" test.tab "PG:dbname=spatial2" -sql "select id,
gridcode from adams_v1 where gridcode=72 limit 50"
This time I got 50 records with the id and gridcode set to the right
types, but no polygons. I tried specifying the geometry:
the_geom, id, gridcode from adams_v1 where gridcode=72 limit 50"
but the result was the same. So I looked for documentation and found
only some *.dox files. So my question is, how do I read the
documentation, and why doesn't the MapInfo conversion work?
Thanks,
- Bill Thoen
