[postgis-users] Spatial indexes
Markus Schaber schabi at logix-tt.com
Mon Sep 18 13:41:53 PDT 2006
Hi, Martin,
Martin Daly wrote:
>> You could give us more details about your view and the
>> queries typically runing against it, so we could help more.
> James' problem is not creating or using indices, but detecting them.
> SIS cannot discover whether or not a geometry column in a view has a
> spatial index.  SIS can do this with a table using standard PostgreSQL
> metadata, but not with a view.
Ah, I understand. Sorry for the confusion I added.
> SIS, when it encounters a table with a non-spatially-indexed geometry
> column, or a view where it cannot detect the spatial index, presents
> users with restricted connection options, to avoid, for example,
> unexpectedly long redraw times when zoomed in on a large dataset.
> As you point out, this is a PostgreSQL problem rather then a PostGIS
> one.
Sounds rather like an SIS prolem now. :-)
Regards,
Markus
