[postgis-users] working with PLSS: state-plane survey system coordinates
Dylan Beaudette dylan.beaudette at gmail.com
Thu Sep 21 15:40:13 PDT 2006
Hi everyone,
Here is a rather odd question:
say i have a vector description of 'sections' as defined in the PLSS
(http://nationalatlas.gov/articles/boundaries/a_plss.html), and I would like
associate legal definitions with a real-world coordinates.
starting with "T10, R10, Section 10, mount diablo base meridian" , it would be
a simple matter to lookup the matching section polygon, locate its centroid,
and dump the x,y coordinates.
however, it is common practice to define a location in terms of 1/4 of 1/4
section, i.e. :
"NE 1/4 of NE 1/4 of Section 10, T10, R10"
the problem then arises: how can i approximately subdivide the section polygon
(as it is usually not a square) such that : the polygon is bisected along
each axis twice:
note that the NE 1/4 of the NE 1/4 of the section is marked with a * . also
note that the section will not always be oriented parallel to the x and y
axis as in the example above.
therefore the question is : is there a generic way to bisect a polygon
resembling a square (an approximation is ok too) within an x,y plane ?
ideas?
thanks!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
