[postgis-users] Problem with pgsql function
Jeremy Palmer
palmerj at xtra.co.nz
Fri Sep 22 14:58:37 PDT 2006
Thanks for the tip, but the translate function (which uses the affine
transform function) will not work on geometries that cross the 180°
longitude line will it? Otherwise your right, I should use it.
Cheers
Jeremy
<< "Bruce Rindahl" rindahl at lrcwe.com
<< Have you considered using the translate() function? I would do exactly
what
<< you are coding and it will work on all geometries.
<< Bruce Rindahl
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060923/20740b65/attachment.html>
