[postgis-users] PgRouting - Open Source routing solution forPostgreSQL! Please help me.
Fay Du
fay.du at versaterm.com
Mon Sep 25 05:58:16 PDT 2006
I have seen similar error once. What I did is I simply removed all ".so"
file and do "make install" again. Then everything was fine. I have no
clue why it was wrong and why it worked. Hope it means something to you.
Fay
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
TECHER David
Sent: Saturday, September 23, 2006 3:59 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PgRouting - Open Source routing solution
hi Nguyen
I've got the same problem as you!
Why? I don't know :(
Nguyen Thi Van An a écrit :
> Hi everybody,
> I already installed pgRouting successful:
> [root at anntv routing]# make install
> /bin/sh /usr/lib/pgsql/pgxs/src/makefiles/../../config/install-sh -c
> -m 644 ./routing_postgis.sql /usr/share/pgsql/contrib
> -m 644 routing.sql /usr/share/pgsql/contrib
> -m 644 ./README.routing /usr/share/doc/pgsql/contrib
> -m 755 librouting.so.0.0 /usr/lib/pgsql/routing.so
> I already export successfully *routing_postgis.sql *and I already copy
> *libCGAL.so* (in /usr/local/cgal/lib/i686_Linux-2.6_g++-4.1.1) to
> */usr/lib/pgsql .
> *But when I export *routing.sql.in* and *routing.sql* to PostgreSQL*
> *, I see error below:
> *ERROR: could not load library "/usr/lib/pgsql/routing.so":
> libCGAL.so: cannot open shared object file: No such file or directory*
> *Anyone has error like me? Please help me!
> Thanks so much,
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
--david;
http://www.postgis.fr
http://www.davidgis.fr
________________________________________________________________________
___
Découvrez un nouveau moyen de poser toutes vos questions quelque soit le
sujet !
Yahoo! Questions/Réponses pour partager vos connaissances, vos opinions
et vos expériences.
http://fr.answers.yahoo.com
