[postgis-users] PgRouting - Open Source routing solution for PostgreSQL! Please help me.
Brent Wood pcreso at pcreso.com
Sat Sep 23 16:47:45 PDT 2006
--- TECHER David <davidtecher at yahoo.fr> wrote:
> hi Nguyen
> I've got the same problem as you!
This is getting technical for me, but an inability to find a library is often
fixed by addig the library directory (/usr/lib/pgsql/) to /etc/ld.so.conf
and running ldconfig?
Brent Wood
> Why? I don't know :(
> Nguyen Thi Van An a écrit :
> > Hi everybody,
> > I already installed pgRouting successful:
> > [root at anntv routing]# make install
> > /bin/sh /usr/lib/pgsql/pgxs/src/makefiles/../../config/install-sh -c
> > -m 644 ./routing_postgis.sql /usr/share/pgsql/contrib
> > -m 644 routing.sql /usr/share/pgsql/contrib
> > -m 644 ./README.routing /usr/share/doc/pgsql/contrib
> > -m 755  librouting.so.0.0 /usr/lib/pgsql/routing.so
> > I already export successfully *routing_postgis.sql *and I already copy
> > *libCGAL.so* (in /usr/local/cgal/lib/i686_Linux-2.6_g++-4.1.1) to
> > */usr/lib/pgsql .
> > *But when I export *routing.sql.in* and *routing.sql* to PostgreSQL*
> > *, I see error below:
> > *ERROR:  could not load library "/usr/lib/pgsql/routing.so":
> > libCGAL.so: cannot open shared object file: No such file or directory*
> > *Anyone has error like me? Please help me!
> > Thanks so much,
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
> --david;
> http://www.postgis.fr
> http://www.davidgis.fr
> ___________________________________________________________________________
> Découvrez un nouveau moyen de poser toutes vos questions quelque soit le
> sujet !
> Yahoo! Questions/Réponses pour partager vos connaissances, vos opinions et
> vos expériences.
> http://fr.answers.yahoo.com
