[postgis-users] -- configure: error: PostgreSQL is required by PostGIS Installing PostGIS --
strk at refractions.net strk at refractions.net
Wed Sep 27 05:54:49 PDT 2006
On Wed, Sep 27, 2006 at 02:35:16PM +0200, Øyvind Vestavik wrote:
> hi Rafael
> Unfortunately, I think your assumption here about where to place PostGis
> before compiling it is incorrect.
> If you installed from RPM you probably don't have the source code for
> PGSQL wich is needed to compile postgis.
It' s long time postgis doesn't need PGSQL sources.
You do need server headers though, that are usually provided as a
separate package (-dev).
--strk;
