[postgis-users] -- configure: error: PostgreSQL is required by PostGIS Installing PostGIS --
Øyvind Vestavik oyvindve at idi.ntnu.no
Wed Sep 27 23:39:21 PDT 2006
Sorry for the misinformation.
Knew what he was doing wrong, but apparantly not what was the correct
answer/way.
Kind Regards
Øyvind
ons, 27,.09.2006 kl. 14.54 +0200, skrev strk at refractions.net:
> On Wed, Sep 27, 2006 at 02:35:16PM +0200, Øyvind Vestavik wrote:
> > hi Rafael
> > Unfortunately, I think your assumption here about where to place PostGis
> > before compiling it is incorrect.
> > If you installed from RPM you probably don't have the source code for
> > PGSQL wich is needed to compile postgis.
> It' s long time postgis doesn't need PGSQL sources.
> You do need server headers though, that are usually provided as a
> separate package (-dev).
> --strk;
> postgis-users mailing list
Kind Regards
Øyvind Vestavik
