[postgis-users] Examples SQL for spatial searches in post gis eg intersect
Maher Karim
Maher_Karim at dorsch.com.jo
Tue Apr 3 22:14:37 PDT 2007
Hi Mohammed,
You can use this example as a guide for you.
select count(*) from layer1,layer2 where layer1.the_geom&&layer2.the_geom
and intersects(layer1.the_geom,layer2.the_geom)
you should use the "layer1.the_geom&&layer2.the_geom" because it will
reduce the query time
Regards
Maher Abdel Karim
GIS systems analyst/Programmer
Dorsch Water and Environment
| | "Mohammed Wahead" |
| | <Mohammed.Wahead at cadcorp.com> |
| | Sent by: |
| | postgis-users-bounces at postgis.refr|
| | actions.net |
| | 04/03/2007 05:32 PM |
| | Please respond to PostGIS Users |
| | Discussion |
| To: <postgis-users at postgis.refractions.net> |
| cc: |
| Subject: [postgis-users] Examples SQL for spatial searches in post gis eg intersect |
Hi folks,
Can anyone point mw in the right direction. I would like examples of SQL
syntax for running spatial searches in postgis. For example what is the SQL
for determining which spatial features intersect with another spatial
feature.
Thanks.
Mohammed Wahead
"Subscribe to Cadcorp eNews at www.cadcorp.com."
GIS & RDBMS Specialist
Cadcorp
Computer Aided Development Corporation Ltd Sterling Court,
Norton Road,
Stevenage, Herts,
SG1 2JY, UK
Tel: +44 (0)1438 731440
Fax: +44 (0)1438 747997
This email is confidential and may be privileged and should not be used,
read or copied by anyone who is not the original intended recipient. If
you
have received this email in error please inform the sender and delete it
from your mailbox or any other storage mechanism. Unless specifically
stated, nothing in this email constitutes an offer by Cadcorp and Cadcorp
does not warrant that any information contained in this email is accurate.
Cadcorp cannot accept liability for any statements made which are clearly
the sender's own and not expressly made on behalf of Cadcorp or one of its
agents. Please rely on your own virus check. No responsibility is taken by
Cadcorp for any damage arising out of any bug or virus infection.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
