[postgis-users] Examples SQL for spatial searches in post gis egintersect
Abd Muhsen abd_muhsen at hotmail.com
Tue Apr 3 22:13:56 PDT 2007
I believe what Mr. Karim said is right. Using the && as an intersection
operator is better since it allow the system to use the index (GiST, if
available of course). I strongly recommend you to look at the following
links. It might be very useful for you.
4.4. Retrieving GIS Data:
http://postgis.refractions.net/docs/ch04.html#id2849854
6.2.2. OpenGIS Operators:
http://postgis.refractions.net/docs/ch06.html#id2854381
Many thanks,
Abdel-Rahman Muhsen
MSc. Geomatics Engineering student
University of Calgary
Canada
>From: Maher Karim <Maher_Karim at dorsch.com.jo>
>Reply-To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>CC: postgis-users
><postgis-users at postgis.refractions.net>,postgis-users-bounces
><postgis-users-bounces at postgis.refractions.net>
>Subject: Re: [postgis-users] Examples SQL for spatial searches in post gis
>egintersect
>Date: Wed, 4 Apr 2007 07:14:37 +0200
>Hi Mohammed,
>You can use this example as a guide for you.
>select count(*) from layer1,layer2 where layer1.the_geom&&layer2.the_geom
>and intersects(layer1.the_geom,layer2.the_geom)
>you should use the "layer1.the_geom&&layer2.the_geom" because it will
>reduce the query time
>Regards
>Maher Abdel Karim
>GIS systems analyst/Programmer
>Dorsch Water and Environment
>|         |           "Mohammed Wahead"                 |
>|         |           <Mohammed.Wahead at cadcorp.com>     |
>|         |           Sent by:                          |
>|         |           postgis-users-bounces at postgis.refr|
>|         |           actions.net                       |
>|         |           04/03/2007 05:32 PM               |
>|         |           Please respond to PostGIS Users   |
>|         |           Discussion                        |
>   |        To:      <postgis-users at postgis.refractions.net>
>   |        cc:
>   |        Subject: [postgis-users] Examples SQL for spatial searches in
>post gis eg  intersect
>Hi folks,
>Can anyone point mw in the right direction. I would like examples of SQL
>syntax for running spatial searches in postgis. For example what is the SQL
>for determining which spatial features intersect with another spatial
>feature.
>Thanks.
>Mohammed Wahead
>"Subscribe to Cadcorp eNews at www.cadcorp.com."
>GIS & RDBMS Specialist
>Cadcorp
>Computer Aided Development Corporation Ltd Sterling Court,
>Norton Road,
>Stevenage, Herts,
>SG1 2JY, UK
>Tel: +44 (0)1438 731440
>Fax: +44 (0)1438 747997
>  This email is confidential and may be privileged and should not be used,
>  read or copied by anyone who is not the  original intended recipient. If
>  you
>  have received this email in error  please inform the sender and delete it
>  from your mailbox or any other storage mechanism. Unless specifically
>  stated, nothing in this email constitutes an offer by Cadcorp and Cadcorp
>  does not warrant that any information contained in this email is
>accurate.
>  Cadcorp cannot accept liability for any statements made which are clearly
>  the sender's own and not expressly made on behalf of Cadcorp or one of
>its
>  agents. Please rely on your own virus check. No responsibility is taken
>by
>  Cadcorp for any damage arising out of any bug or virus infection.
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
