[postgis-users] creating linestrings from points, complexish linestrings
Martin Davis
mbdavis at refractions.net
Thu Apr 5 08:43:23 PDT 2007
Hmm, that is complexish. I see now that pointnumber can be used as the
ordering, so that's good. But it looks like you might have to do an
arbitrary-depth self-join to chain all the points in a particular list
together - ugly. 'Fraid I don't have any good ideas about how to
aggregate the sequences of points into linestrings. Perhaps someone
else on the list will.
Rhys Stewart wrote:
> here is an excerpt from the table:
> parish | pointnumber | parent | devicetype
> KSAS | 3 | | START
> KSAS | 4 | 3 | INTER
> KSAS | 5 | 4 | INTER
> KSAS | 6 | 5 | END
> KSAS | 7 | 3 | INTER
> KSAS | 8 | 7 | END
> KSAS | 9 | 7 | END
> KSAS | 10 | | START
> KSAS | 11 | 10 | INTER
> KSAS | 12 | 11 | INTER
> KSAS | 13 | 12 | END
> KSAS | 14 | | START
> KSAS | 15 | 14 | END
> On 4/4/07, Martin Davis <mbdavis at refractions.net> wrote:
>> First of all, don't you need some kind of ordering attribute on the
>> points? Otherwise how would you determine the order the points occur in
>> the linestring?
>> Rhys Stewart wrote:
>> > Hi all,
>> > I have the following table:
>> > CREATE TABLE tmp.children
>> > parish character varying(50),
>> > pointnumber numeric(18),
>> > parent character varying(254),
>> > devicetype character varying(50),
>> > coordfix geometry
>> > The table holds a parent-child relationship in columns pointnumber and
>> > parent.
>> > i.e., if a point has a parent the pointnumber for that parent is in
>> > the parent field.
>> > The devicetype can either be Start, Inter or End. The only time a row
>> > has no parent is when its devicetype is start. There can be any number
>> > of inters.
>> > I would like to create one linestring encompassing an entire
>> > start-inter-end sequence and am having trouble wrapping my brain
>> > around it.
>> > Any suggestions?
>> > Thanks
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
Martin Davis
(250) 383-3022
