[postgis-users] creating linestrings from points, complexishlinestrings
Jason Birch
Jason.Birch at nanaimo.ca
Thu Apr 5 09:28:19 PDT 2007
I don't think that it will help in this particular case (the first line
is a multilinestring) but the MySQL GROUP_CONCAT function can be a handy
way of avoiding procedural language with similar problems.
For instance, with certain data structures you could pull the geometry
out into x/y values, build a WKT linestring with GROUP_CONCAT, and then
flip it back into a geometry.
I'm not familiar enough with PostGIS to know; does MakeLine(geometry
set) do the same thing?
The MySQLCompat library has an example of adding GROUP_CONCAT to
PostgreSQL:
http://pgfoundry.org/projects/mysqlcompat/
-- GROUP_CONCAT()
-- Note: only supports the comma separator
-- Note: For DISTINCT and ORDER BY a subquery is required
CREATE OR REPLACE FUNCTION _group_concat(text, text)
RETURNS text AS $$
SELECT CASE
WHEN $2 IS NULL THEN $1
WHEN $1 IS NULL THEN $2
ELSE $1 operator(pg_catalog.||) ',' operator(pg_catalog.||) $2
END
$$ IMMUTABLE LANGUAGE SQL;
CREATE AGGREGATE group_concat (
BASETYPE = text,
SFUNC = _group_concat,
STYPE = text
Jason
Martin Davis wrote:
> Hmm, that is complexish. I see now that pointnumber can be
> used as the ordering, so that's good. But it looks like
> you might have to do an arbitrary-depth self-join to chain
> all the points in a particular list together - ugly. 'Fraid
> I don't have any good ideas about how to aggregate the
> sequences of points into linestrings. Perhaps someone else
> on the list will.
Rhys Stewart wrote:
> here is an excerpt from the table:
> parish | pointnumber | parent | devicetype
> KSAS | 3 | | START
> KSAS | 4 | 3 | INTER
> KSAS | 5 | 4 | INTER
> KSAS | 6 | 5 | END
> KSAS | 7 | 3 | INTER
> KSAS | 8 | 7 | END
> KSAS | 9 | 7 | END
> KSAS | 10 | | START
> KSAS | 11 | 10 | INTER
> KSAS | 12 | 11 | INTER
> KSAS | 13 | 12 | END
> KSAS | 14 | | START
> KSAS | 15 | 14 | END
