[postgis-users] creating linestrings from points, complexishlinestrings
Rhys Stewart
rhys.stewart at gmail.com
Thu Apr 5 09:43:23 PDT 2007
plpgsql to the rescue...sort off
a recursive function did the trick...for the most part
CREATE OR REPLACE FUNCTION tmp.whodn_1(in whoid text, out tot text)
RETURNS setof text as
$BODY$
DECLARE
myrec record;
qot text;
thol text;
outro bigint;
BEGIN
--qot := 'SELECT count(pointnumber) FROM tmp.testpoints_ where parent
= '|| quote_literal(whoid);
--raise notice '-> %',qot;
--EXECUTE qot into outro ;
qot := 'SELECT pointnumber FROM tmp.testpoints_ where parent = '||
FOR myrec in EXECUTE qot LOOP
tot := whoid||','||myrec.pointnumber;
thol := myrec.pointnumber;
RETURN NEXT;
--tot := null;
FOR myrec in select * from tmp.whodn_1(thol) LOOP
--tot := null;
tot := split_part(tot,',',1)||','||myrec.tot;
IF
RETURN NEXT;
--tot := null;
END LOOP;
END LOOP;
RETURN;
END;
$BODY$
LANGUAGE 'plpgsql' VOLATILE;
thats just the shell, but it goes through and gives me the points in
the correct order. :-)
On 4/5/07, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> I don't think that it will help in this particular case (the first line
> is a multilinestring) but the MySQL GROUP_CONCAT function can be a handy
> way of avoiding procedural language with similar problems.
> For instance, with certain data structures you could pull the geometry
> out into x/y values, build a WKT linestring with GROUP_CONCAT, and then
> flip it back into a geometry.
> I'm not familiar enough with PostGIS to know; does MakeLine(geometry
> set) do the same thing?
> The MySQLCompat library has an example of adding GROUP_CONCAT to
> PostgreSQL:
> http://pgfoundry.org/projects/mysqlcompat/
> -- GROUP_CONCAT()
> -- Note: only supports the comma separator
> -- Note: For DISTINCT and ORDER BY a subquery is required
> CREATE OR REPLACE FUNCTION _group_concat(text, text)
> RETURNS text AS $$
> SELECT CASE
> WHEN $2 IS NULL THEN $1
> WHEN $1 IS NULL THEN $2
> ELSE $1 operator(pg_catalog.||) ',' operator(pg_catalog.||) $2
> END
> $$ IMMUTABLE LANGUAGE SQL;
> CREATE AGGREGATE group_concat (
> BASETYPE = text,
> SFUNC = _group_concat,
> STYPE = text
> Jason
> Martin Davis wrote:
> > Hmm, that is complexish. I see now that pointnumber can be
> > used as the ordering, so that's good. But it looks like
> > you might have to do an arbitrary-depth self-join to chain
> > all the points in a particular list together - ugly. 'Fraid
> > I don't have any good ideas about how to aggregate the
> > sequences of points into linestrings. Perhaps someone else
> > on the list will.
> Rhys Stewart wrote:
> > here is an excerpt from the table:
> > parish | pointnumber | parent | devicetype
> > KSAS | 3 | | START
> > KSAS | 4 | 3 | INTER
> > KSAS | 5 | 4 | INTER
> > KSAS | 6 | 5 | END
> > KSAS | 7 | 3 | INTER
> > KSAS | 8 | 7 | END
> > KSAS | 9 | 7 | END
> > KSAS | 10 | | START
> > KSAS | 11 | 10 | INTER
> > KSAS | 12 | 11 | INTER
> > KSAS | 13 | 12 | END
> > KSAS | 14 | | START
> > KSAS | 15 | 14 | END
> postgis-users mailing list
