[postgis-users] newbie install problem with GEOS
Nicolas Ribot
nicky666 at gmail.com
Thu Apr 5 14:32:09 PDT 2007
Have a look at:
http://www.kyngchaos.com/software/unixport
All common GIS packages compiled for Mac, as dmg images.
Very, very handy !
With latest versions of PostGIS, GDAL/OGR, MapScript, etc.
Nicolas
On 4/3/07, trobertson at gbif.org <trobertson at gbif.org> wrote:
> Hi,
> I am newbie to POSTGIS and to my mac, and banging my head against the desk
> trying to get it to install.
> I have POSTGRES installed and working I thought I had POSTGIS working
> only to find that when I try and do a CONTAINS() I get the "you need to
> build with GEOS" message...
> So, I try and follow the destructions, I downloaded PROJ4 and GEOS and in
> both do:
> su root
> ./configure
> make
> make install
> then copy the POSTGIS to the POSTGRES/contrib directory.
> I change the Makefil.contrib to have
> USE_GEOS=1
> GEOS_DIR=/usr/local
> USE_PROJ=1
> PROJ_DIR=/usr/local
> and when I run the ./configure in the
> /usr/local/src/postgres/postgresql-8.2.3/contrib/postgis-1.2.1 I get
> checking for geos-config... no
> checking for proj... no
> and the Makefile.config gets overridden to have 0's again where I set it
> to 1...
> Is GEOS installed? How can I test? Why is the config getting overriden?
> Please help - and be aware that I have very little clue as to what the C
> compiler setup is really doing so to be honest I need an idiots guide!
> Any help greatly appreciated at this point...
> Thanks
> Tim
> postgis-users mailing list
