[postgis-users] newbie - versioning problem
trobertson at gbif.org trobertson at gbif.org
Fri Apr 6 10:57:37 PDT 2007
Fixed it by using the latest RC release for GEOS... I was using the latest
stable version.
> Hi,
> I have built what I beleived to be th latest version of PostGIS and
> Postgres on my mac but get the following error:
> STATEMENT:  select id,name from o where
> Contains(GeomFromText('Polygon((-10 -10, -10 10 , 10 10, 10 -10, -10
> -10))'), geom);
> ERROR:  could not load library "/usr/local/pgsql/lib/liblwgeom.1.2.so":
> dlopen(/usr/local/pgsql/lib/liblwgeom.1.2.so, 10): Library not loaded:
> /usr/local/lib/libgeos_c.1.dylib
>   Referenced from: /usr/local/pgsql/lib/liblwgeom.1.2.so
>   Reason: Incompatible library version: liblwgeom.1.2.so requires version
> 5.0.0 or later, but libgeos_c.1.dylib provides version 3.0.0
> CONTEXT:  SQL function "geomfromtext" statement 1
> Im pretty new to this... can someone please point me in the right
> direction?
> many thanks
> Tim
> postgis-users mailing list
