[postgis-users] Problems with PHP and PostgreSQL/PostGIS
Obe, Regina
robe.dnd at cityofboston.gov
Fri Apr 13 05:24:34 PDT 2007
When you created your table it appears you created it as
FahrtenbuchTabelle, but in your PHP sql, you don't have the table name
quoted, it will take what you have and insert into a table called
fahrtenbuchtabelle. All table names that are not quoted in sql will be
lowercased when passed to the processor.
To minimize on headache, you really should rename your table in
PostgreSQL to fahrtenbuchtabelle. Note that PostgreSQL table names are
case sensitive so FahrtenbuchTabelle and fahrtenbuchtabelle are not the
same name.
Other possibly potential problem, I can't tell how you are passing in
your $datum date, but may need to be quoted.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Gerald Baumgartner
Sent: Friday, April 13, 2007 8:14 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Problems with PHP and PostgreSQL/PostGIS
Hi everyone!
I have created a table and now I want to put a GPS Logfile into this
table with a php file. But the php file doesn't do the inserts.
Please can someone help me!
The error message from the php file in firefox:
Warning: pg_query() [function.pg-query
<http://localhost/GpsDaten/function.pg-query> ]: Query failed: ERROR:
relation "fahrtenbuchtabelle" does not exist in
C:\ms4w\Apache\htdocs\GpsDaten\GPS_Daten_einlesen.php on line 103
Here are the commands in the php file:
if($z_eintraege==2)
$sql_befehl="INSERT INTO
FahrtenbuchTabelle(FID,Date_Start_Fahrt,Date_Insert,Strecke) VALUES
($z_eintraege,$datum,$datum,GeometryFromText('LINESTRING($breitengrad1
$laengengrad1, $breitengrad $laengengrad)',4326))";
$res=pg_query($connection,$sql_befehl);
$sql_befehl_select="SELECT max(FID) as fid from
FahrtenbuchTabelle";
$fahrtnummer=pg_query($connection,$sql_befehl_select);
if($z_eintraege>2)
$sql_befehl_append="UPDATE FahrtenbuchTabelle SET
Strecke=AddPoint(Strecke,GeomFromText('POINT($breitengrad
$laengengrad)',4326)) where FID='$fahrtnummer'";
$result=pg_query($connection,$sql_befehl_append);
And there is my table in postgresql/postgis:
CREATE TABLE "FahrtenbuchTabelle"
"FID" numeric NOT NULL,
"Date_Start_Fahrt" date NOT NULL,
"Date_Insert" date NOT NULL,
"Strecke" geometry,
CONSTRAINT "FahrtID" PRIMARY KEY ("FID"),
CONSTRAINT "enforce_dims_Strecke" CHECK (ndims("Strecke") = 2),
CONSTRAINT "enforce_geotype_Strecke" CHECK (geometrytype("Strecke") =
'LINESTRING'::text OR "Strecke" IS NULL),
CONSTRAINT "enforce_srid_Strecke" CHECK (srid("Strecke") = 4326)
WITHOUT OIDS;
ALTER TABLE "FahrtenbuchTabelle" OWNER TO postgres;
Already thankful for any ideas.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070413/9877f906/attachment.html>
