[postgis-users] Problems with PHP and PostgreSQL/PostGIS
Gerald Baumgartner baumgartner.gerald at gmail.com
Fri Apr 13 05:55:23 PDT 2007
I have renamed the tablename, but now there are other errors:
*Warning*: pg_query()
[function.pg-query<http://localhost/GpsDaten/function.pg-query>]:
Query failed: ERROR: column "date_start_fahrt" is of type date but
expression is of type integer at character 36 HINT: You will need to rewrite
or cast the expression. in *
C:\ms4w\Apache\htdocs\GpsDaten\GPS_Daten_einlesen.php* on line *103*
Query failed: ERROR: invalid input syntax for type numeric: "" in *
C:\ms4w\Apache\htdocs\GpsDaten\GPS_Daten_einlesen.php* on line *112*
php Code:
    $timestamp=time();
    $datum=date("d/m/y",$timestamp);
    if($z_eintraege==2)
       $sql_befehl="INSERT INTO
fahrtenbuchtabelle(fid,date_start_fahrt,date_insert,strecke) VALUES
($z_eintraege,$datum,$datum,GeometryFromText('LINESTRING($breitengrad1
$laengengrad1, $breitengrad $laengengrad)',4326))";
       $res=pg_query($connection,$sql_befehl);
       $sql_befehl_select="SELECT max(FID) as fid from fahrtenbuchtabelle";
       $res_fid=pg_query($connection,$sql_befehl_select);
       $fahrtnummer=pg_result($res_fid,"fid");
    if($z_eintraege>2)
      $sql_befehl_append="UPDATE fahrtenbuchtabelle SET
strecke=AddPoint(strecke,GeomFromText('POINT($breitengrad
$laengengrad)',4326)) where fid='$fahrtnummer'";
      $result=pg_query($connection,$sql_befehl_append);
Gerald
2007/4/13, Obe, Regina <robe.dnd at cityofboston.gov>:
>  When you created your table it appears you created it as FahrtenbuchTabelle,
> but in your PHP sql, you don't have the table name quoted, it will take what
> you have and insert into a table called fahrtenbuchtabelle.  All table names
> that are not quoted in sql will be lowercased when passed to the processor.
> To minimize on headache, you really should rename your table in PostgreSQL
> to fahrtenbuchtabelle.  Note that PostgreSQL table names are case
> sensitive so FahrtenbuchTabelle  and fahrtenbuchtabelle are not the same
> name.
> Other possibly potential problem, I can't tell how you are passing in your
> $datum date, but may need to be quoted.
> Hope that helps,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Gerald
> Baumgartner
> *Sent:* Friday, April 13, 2007 8:14 AM
> *To:* postgis-users at postgis.refractions.net
> *Subject:* [postgis-users] Problems with PHP and PostgreSQL/PostGIS
> Hi everyone!
> I have created a table and now I want to put a GPS Logfile into this table
> with a php file. But the php file doesn't do the inserts.
> Please can someone help me!
> The error message from the php file in firefox:
> *Warning*: pg_query() [function.pg-query<http://localhost/GpsDaten/function.pg-query>]:
> Query failed: ERROR: relation "fahrtenbuchtabelle" does not exist in *
> Here are the commands in the php file*:
>     if($z_eintraege==2)
> FahrtenbuchTabelle(FID,Date_Start_Fahrt,Date_Insert,Strecke) VALUES
> FahrtenbuchTabelle";
>        $fahrtnummer=pg_query($connection,$sql_befehl_select);
>     if($z_eintraege>2)
>       $sql_befehl_append="UPDATE FahrtenbuchTabelle SET
> Strecke=AddPoint(Strecke,GeomFromText('POINT($breitengrad
> $laengengrad)',4326)) where FID='$fahrtnummer'";
> And there is my table in postgresql/postgis:
> CREATE TABLE "FahrtenbuchTabelle"
>   "FID" numeric NOT NULL,
>   "Date_Start_Fahrt" date NOT NULL,
>   "Date_Insert" date NOT NULL,
>   "Strecke" geometry,
>   CONSTRAINT "FahrtID" PRIMARY KEY ("FID"),
>   CONSTRAINT "enforce_dims_Strecke" CHECK (ndims("Strecke") = 2),
>   CONSTRAINT "enforce_geotype_Strecke" CHECK (geometrytype("Strecke") =
> 'LINESTRING'::text OR "Strecke" IS NULL),
>   CONSTRAINT "enforce_srid_Strecke" CHECK (srid("Strecke") = 4326)
> WITHOUT OIDS;
> ALTER TABLE "FahrtenbuchTabelle" OWNER TO postgres;
> Already thankful for any ideas.
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070413/5b40a72b/attachment.html>
