[postgis-users] PostGIS Install Failure: make check, lwpostgis.sql, ... errors
Stefan Oberhauser
stefan.obh at mcnon.com
Tue Apr 17 14:58:25 PDT 2007
Mark,
thank you for the answer.
I ugraded GEOS to version 2.2.3. Now without error messages I rebuilt
PostGIS once again.
But
psql -f /usr/share/postgresql/8.1/contrib/postgis-1.2.1/lwpostgis.sql -d
mytestdb still fails as before:
psql:/usr/share/postgresql/8.1/contrib/postgis-1.2.1/lwpostgis.sql:4378:
ERROR: current transaction is aborted, commands ignored until end of
transaction block.
ROLLBACK
On another PC with Ubuntu 6.10 I had no problems - with higher versions
available in the repository. So I decided to make an upgrade to Ubuntu
6.10 also and not to struggle with old versions.
Thanks and kind regards,
Stefan.
Am Montag, den 16.04.2007, 07:26 +0100 schrieb Mark Cave-Ayland:
> On Mon, 2007-04-16 at 00:16 +0200, Stefan Oberhauser wrote:
> (cut)
> > I've got stuck with this. I've found some similar threads in the archive
> > but I need some additional hints.
> > Thank you very much if there is anybody who has an idea what I could try
> > to resolve this installation problem.
> This is a known issue with older builds of GEOS - see
> http://postgis.refractions.net/pipermail/postgis-users/2007-February/014844.html
> for more information. The easiest way to solve this is to upgrade GEOS
> to the latest version in the 2.2 branch and rebuild PostGIS; it would
> be quite handy if the author of the has_arc() function (Mark Leslie?)
> can commit a fix for non-CAPI GEOS to SVN, otherwise we should clearly
> document that PostGIS 1.2.x branch requires GEOS 2.2.x. I'll CC Mark
> and see if he can suggest a suitable fix.
> (cuts lots)
> > 6) createdb mytestdb: runs without error.
> > 7) createlang plpqsql mytestdb:
> This is just a typo - what you need is: createlang plpgsql mytestdb. But
> I'm afraid you'll still need to upgrade GEOS to 2.2.x, then re-configure
> and "make install".
> Kind regards,
> Mark.
> postgis-users mailing list
